Futaba motagare 2,4 system
Started by Benny, 2011-02-20, 20:42:19
Benny
Vad är skillnaden på motagare
6014FS & 6014HS
Benny
Benny
Benny
Är det någon som vet
Tacksam för svar
Benny
Benny
Gullberg
Hej Benny,
Nedan saxat från RC Universe.com
The FS is the \"old\"  2.4GHz receiver and the HS it the \"new\" 2.4 GHz receiver which has the option of the first 6 channels been operated in a \"High Speed\" mode. This will only work on digital servos. A 7mS pulse instead of 14 mS pulse.
The gold dot was added in between the antennae of the later versions of the FS receiver. A modification was done to address the high temperature issue with the early versions of the FS receiver which could lock out at temperatures above 70 deg C.
//Gullberg
Krill Yak 55M 33%
Krill Ultimate 300KS 39% MK1
CARF Extra 300SC 41%
EF Extra 300 85"
DA / DLE / GP
Jeti DS 24
