Säljes: Scorpion S3014-18
Started by Mats_N, 2012-10-03, 20:28:31
Rensar förråden inför en flytt.
Scorpion S3014-18
Flugen i en MPX Acromaster på 3S och APC-E 11x7.
Specifications
Stator Diameter   30.0 mm (1.181 in)
Stator Thickness   14.0 mm (0.551 in)
No. of Stator Arms   12
Magnet Poles           14
Motor Wind           18 Turn Delta
Motor Wire           14-Strand 0.21mm
Motor Kv                   1064 RPM / Volt
No-Load Current (Io)   1.67 Amps
Motor Resistance (Rm)   0.043 Ohms
Max Continuous Current   40 Amps
Max Continuous Power   600 Watts
Weight                           122.1 Grams (4.31 oz)
Outside Diameter   37.50 mm (1.476 in)
Shaft Diameter             4.97 mm (0.197 in)
Body Length           31.9 mm (1.256 in)
Overall Shaft Length   70.5 mm (2.776 in)
400 kr
http://www.scorpionsystem.com/files/i473_data_chart.htm
41.87 KB
Mats Nordén
mail: mats_norden@telia.com
mobil: 0725-152175
