Nytt roderservo från Hitec
Started by Mikael_Ingemarson, 2012-12-15, 09:09:30
Ser najs ut[:)]
19.03 KB
8.47 KB
Attention giant scale modelers: Your dream rudder servo has arrived!
Hitec is proud to introduce our high voltage, coreless, steel gear, digital rudder servo, the HS-7956SHR.
Our new digital HS-7956SHR steel gear, rudder servo is unlike anything you've seen on the market. Featuring an all-inclusive design with its own Secraft pull-pull system and wide mounting tabs measuring 1.73 x 1.54 inches (44 x 39mm), this tremendous servo eliminates the need for a separate rudder servo top case. The HS-7956SHR is equipped with a high performance coreless motor, ultra heavy-duty, ball bearing-supported metal arm and two adjustable ball link rods making it a monster performer for your 30 to 80cc giant scale aircraft. The oversized ball bearings provide strength and stability in order to eliminate any rocking motion of the output arm. For your convenience, we also developed a rudder tray conversion kit. Let this outstanding rudder servo get you flying in the right direction!
http://www.zdz.se
MTW-dämpfer
Har varit synlig på webben och shoppar ganska länge (halvår?) men inte sett om det går att beställa. Har du kommit över eller sett ett IRL?
Klart innovativt.
